pablonavarrob
Hi everyone,
I already posted on facebook for help, but trying my luck here just in case some more of you can take a look at this issue.
I've been holding off until now to attempt to build a Son of Ben pedal. I built everything according to the guide, been reading a lot about this build and attempted it on Sunday.
Once I plugged it in, I noticed that there is indeed sound coming through bypass mode, but, when I turn the effect on, there is nothing. Only some light hizz from the amp itself as far as I can tell. I cannot see any bridges or anything weird in the board. I have checked twice all the components before installing them. I don't have a multimeter at hand right now, will be getting one in a few days, but in case someone sees something obvious that I am not noticing, please let me know, I'd be very grateful, this is a pedal I've been wanting to build for a long time.
I think there might actually be either a broken component or a bridge, because if I touch the OUT pin in the board, the one going to the footswich, there is noise coming through the amp which changes character as I move the pots. I just got a multimeter and tested the value for all resistors, which match what is specified on the build docs. Edit: I also made sure to bias the J201 to 4.5-5V.
Any ideas?
Adding some pictures below, lmk if you need anything else.
Any ideas?
