farwest1 Member Jun 7, 2020 #1 What are your favorite tight high gain pcbs you’ve built? Last edited: Jun 7, 2020
Nostradoomus Well-known member Jun 7, 2020 #2 Tight Metal if you can find a board for it somewhere. The Friedman/Revv stuff sounds pretty good but I haven’t built any of them.
M mstrat New member Jun 7, 2020 #4 Barry said: The Sanguine Click to expand... I'm building this now, and - assuming it's identically to the G4 - totally agree.
farwest1 Member Jun 7, 2020 #5 Barry said: The Sanguine Click to expand... is it based on the red channel of the Bogner Ecstacy?
M mstrat New member Jun 7, 2020 #6 It's the Revv G4. Not sure if that is based on the bogner, though.
Robert Reverse Engineer Jun 7, 2020 #7 Want to see something interesting? Take a look at the Tyrian and Thermionic Distortion schematics side-by-side.......
farwest1 Member Jun 7, 2020 #8 Robert said: Want to see something interesting? Take a look at the Tyrian and Thermionic Distortion schematics side-by-side....... Click to expand... Ok, so the Sanguine is a red channel distortion based on the Revv G4 (in turn maybe based on the Bogner Ecstacy red channel.) What is a purple channel (Tyrian)? Revv G3?
PapaBear Well-known member Jun 7, 2020 #9 farwest1 said: Ok, so the Sanguine is a red channel distortion based on the Revv G4 (in turn maybe based on the Bogner Ecstacy red channel.) What is a purple channel (Tyrian)? Revv G3? Click to expand... Yes and the Malachite is the Green Channel Overdrive
farwest1 Member Jun 7, 2020 #10 Barry said: Yes and the Malachite is the Green Channel Overdrive Click to expand... What’s the difference between red, green, purple?
PapaBear Well-known member Jun 7, 2020 #11 farwest1 said: What’s the difference between red, green, purple? Click to expand... I haven't built the other two yet, but they all are based on Revv amp channels, the Green is an overdrive and Purple and Red high gain, look them up on Reverb, probably better descriptions there
temol Well-known member Jun 8, 2020 #12 No, Sanguine is not based on Bogner amp. It's based on REVV amp (Generator 120 if I'm correct).
