Cybercow
Another excellent PCB from PedalPCB (Robert). This is the Binaura Stereo FV-1. If you like to work with stereo effects, this is one to build and get onto your floor space (pedalboard).
Instead of using mono jacks across all the I/O ports, I place a switching jack at the 2nd input to short the two inputs when only one input is used.
The EEPROM is not installed in the photos cuz the EEPROM is in my FV-1 Development Board being prepped for the eight FV-1 patches I'm creating with SpinCAD Designer. I threw some quick stereo FV-1 patches together for initial testing just hear how stereo sounds. (It's awesome!) And once I've finished creating and tweaking all 8 of the patches, I'll post them in a post in the "Spin FV-1 Development" forum group. I'll be updating (adding) the patches there soon. All the stereo FV-1 patches will be shared as SpinCAD Designer and SpinASM files.
I created a Tayda Drills template for the 1590BB enclosure size here: Tayda Drill Template for the Binaura.
(MIND YOU, I BENT THE OUTER POTS OUT A BIT SO THE POTS SIT A BIT WIDER APART.)
Thanks for looking. Happy building!
