Blue shoe gai pan
Built this circuit, this is my third one and for some reason the sweep and mid control have no audible effect. Isolated the dual gain pot, reflowed all my points on the pots, push works so the haunting mids circuit is working I'm just stumped. Everything on the pedal works. Fets are biased at 4.5v. Help please! 20221221_181623.jpg 20221221_181632.jpg 20221221_181642.jpg 20221221_181652.jpg 20221221_182145.jpg 20221221_182200.jpg 20221221_182209.jpg 20221221_182224.jpg 20221221_182155.jpg
Your sweep pot lugs, 4,5, and 6 specifically, look like they need to be reflowed. You can see I. The schematic, the miss and sweep pot are in the same audio path, so start with those values.
20221222_175423.jpg solder-sucked and resoldered the pot, still no change, looking at the schematic, it seems as though something is wrong where the signal splits after IC1.1 pin 1 and ties back in after IC2.1 pin 1 cause I'm still getting signal through the circuit. Something must be wrong with either r5, r6, r8, r7, c3, c4 r9, r11, r10, sweep pot or mid pot, or IC2. Which is all located underneath the sweep pot, should've desoldered the whole thing at once 🤦‍♂️these dual pot insulators don't look like they have a conductive/nonconductive side.
One thing I would do is clean the solder off the board with isopropyl alcohol and a toothbrush. The solder could cause shorts in rare cases and it would make it easier to see the joints.
That wasn't the problem... think I might just leave it how it is and deal. I'll just run my haunting mids into it for now. We will see how well I sleep knowing it's not perfect and go from there 20221222_191035.jpg
Did you check that the dual gang pot works? I usually test all components (pots and switches included) before soldering them in. The one time I failed to do so I had a faulty SPST switch that I had to replace. Also I would put a piece of cardboard between the dual gang and the pot above it. I’ve had shorts like that with dual pots before. They can be a tight fit.
It is working weirdly. Because It starts at 100k and goes down when tweaking up. :(
Regarding the cardboard between the dual gang and pot, do you have an example of how to do this, please?
Updating. I only read some value by testing the pot between lug 1 and lug 3. (starting at 100k and lowering)
Additionally, the dual gang pot does need to be insulated from the board as there are no available dust seals for a dual gang pot. PedalPCB carries a dual gang pot insulator under the Utility category. You can use something firm to achieve this as well, just don't try electrical tape or thick heat shrink as the sharp solder joints underneath will eventually poke through it causing a short. The insulator is made out of the same material as the pcb so I recommend something firm like that if you don't want to wait for the insulator. You can test if this is the issue by bending the pot towards the foot switch side of the circuit ever so slightly just to lift it off the pcb a little bit, with the circuit removed from the enclosure
It looks like the insulator is there. But there may be a short against the other pot because dual pot take a bit more space overall.
