Nah it’s just an on/on switch... it’s one of the little ones so it just looks like that I’m the picture...Did you use a ON/OFF/ON SPDT Toggle, The toggle appears in the Middle in the Picture.
Tidy Build, Did you see my post to add some Bling, YMMV :
Enhancing Your Pedals
Here are 2 Pedals that I purchased years ago, Still have them. The Lovepedal E6 comes with no Labels for the Knobs. I had my Sign Writer cut out these Vinyl Letters in L, D, T, M, B in Black & Silver. The B.Y.O.C Overdrive II Is in a awesome Arlon Prince enclosure worth around $100.00 AU at the...forum.pedalpcb.com
Try putting the switch in the middle position. In between kind of like the old Strat hacks they used when they only had three position switches. Sounds great!Nah it’s just an on/on switch... it’s one of the little ones so it just looks like that I’m the picture...
that’s cool
I like that enclosure.!.!!
I am trying to avoid ordering it from mouser just for one resistor and rather combine 2 common values to match.Matching the Colour Bands, its 53k6 ( 53.6K )
Readily available at Mouser, Futurlec.
Has anyone did this and can advise the values he used?
Just spoke with PedalPCB, said 51k or 56k should be fine , I would have used 56k also!I am trying to avoid ordering it from mouser just for one resistor and rather combine 2 common values to match.
I used to order from Futurlec years ago, their stuff still pretty good?Matching the Colour Bands, its 53k6 ( 53.6K )
Those are just left over legs off resistors...Some tidy looking work for sure! What’s the story with the in and out connections on the foot switch?
I thought it was something like that but I didn’t want to miss a trick. Admiring your solder work...really well done!I use thicker gauge wire on my inputs and outputs and for some reason when I solder em there’s always a long spike coming off of those two so I just snip it off...
