Bring out yer Diptrace
Dredging up a thread.. this may be a dumb question, but how are you setting up the pot locations on your PCB?
This is how I do it.
I typically let graphic design drive PCB design unless I’m using a PedalPCB predrilled unit.
Exactly this. Pot location is set by how the front of my pedal is designed to look, then I subtract 16mm from the Y coordinate of the knob position to place the pot pads. All of this is much easier if you design the board with the origin point being the centre of the pedal enclosure and not just the centre of the PCB itself.
I'm really excited about this layout so I wanted to share. I already make an Ampeg B-15N preamp with a 12AX7, but I always wanted to try one with a 6SL7 like the original. I wasn't able to get it into a 125B, but it should fit into a 1590BBS.
I absolutely love 6SL7 for bass applications, and 12AX7 usually not so much, so...SWEET!
Some more questions for those with some experience..
What's your take on copper pours? Ground on both layers? Ground + VCC?
Pour clearance? Currently looking at 0.25mm/0.01", any thoughts?
I try and do ground layers both top and bottom. I've done VREF on a plane before, but it was because I was having trouble routing the board without it. I just use the default clearance in DipTrace and have not had an issue with it.
To keep a fine thread going..
What are your thoughts on where to take power for the LED? I see some designers taking it before the reverse polarity protection diode, and others putting it after. Any reason not to go the latter way? If you were using a relay break-out board then you could save on the protection diode there (it's not a high cost but it is another component to manage..).
Nothing technical from me here, but rather something pragmatic. I tend to copy the power schematic from my earlier designs and reuse the generic parts in each subsequent layout. This has meant my boards have a 9V line for the LED that branches out prior to the diode, as the first circuit recipes I ever copied were laid out that way. Now it's an inherited feature of my later designs. I'm open to improvements if a case can be made that it's more important than mere personal preference.
I've been tempted by the SMD service, but they don't do DDP for the EU with it. May have to bite the bullet and try..
In any case, a few of the things I've been working on to share the love.
Chuck's FET/Ge Boost:
A Pharoah Muff, trying to route based on audio path rather than aesthetics:
Proto-board for mini breadboards plus pots:
Chuck's basic relay made for 1590B:
@dan.schumaker - I have had loads of issues with uploading the CPL and BOM files previously and could never get it to work but I’ve had a breakthrough today with this PCB and managed to get it working! The amount you fit in a 1590A is beyond belief! 😂
Is "PirateCat" the name of the effect or the name of your pedal-company-to-be?
Name of the "pedal-company-to-be" sounds about right. :D I was thinking about naming the pedal Brünnhilde fuzz. It is also a goddess and a cat...
