Help or not, if that's your first attempt, I have no doubt you're also going to be really good at this!Some of you guys are really good at this! Here's my first attempt, and I had a lot of help.
As someone about to order the Bottlehead Crack OTL tube amp, I would totally buy and build this!So I designed an OTL (output transformerless) tube headphone amp
Same, not the bottlehead, but same.As someone about to order the Bottlehead Crack OTL tube amp, I would totally buy and build this!
It's actually a fairly straightforward design, I was thinking about making it available as a project if I liked it. I'll let everyone know. You need a power transformer and a chassis, and the power tube is a 6AS7G which isn't a common one, but otherwise should be fairly easy to put together if you've ever built an amp (or even a reasonably complex pedal).Same, not the bottlehead, but same.
have you tried the DXF method I have mentioned?It does, but diptrace does a really shitty job at it and makes it look all chunky
Inkscape doesn't export to DXF.have you tried the DXF method I have mentioned?
There is also this project but I haven't tried it yet. You could convert SVG to gerber and import it into your project.
GitHub - jaseg/gerbolyze: Directly render SVG overlays into Gerber and Excellon files
Directly render SVG overlays into Gerber and Excellon files - jaseg/gerbolyzegithub.com
How did this board end up turning out for you? The layout looks very slick.I was looking at the Spaceman Gemini IV
I was breadboarding it from my schematic and realized I left out a couple components and I haven't gotten back to it yet. Squeezing a few more things in isn't such an easy task. No promises as to when I'll do that yet. It's on my list.How did this board end up turning out for you? The layout looks very slick.
