Name of the "pedal-company-to-be" sounds about right.Is "PirateCat" the name of the effect or the name of your pedal-company-to-be?
Help or not, if that's your first attempt, I have no doubt you're also going to be really good at this!Some of you guys are really good at this! Here's my first attempt, and I had a lot of help.
As someone about to order the Bottlehead Crack OTL tube amp, I would totally buy and build this!So I designed an OTL (output transformerless) tube headphone amp
Same, not the bottlehead, but same.As someone about to order the Bottlehead Crack OTL tube amp, I would totally buy and build this!
It's actually a fairly straightforward design, I was thinking about making it available as a project if I liked it. I'll let everyone know. You need a power transformer and a chassis, and the power tube is a 6AS7G which isn't a common one, but otherwise should be fairly easy to put together if you've ever built an amp (or even a reasonably complex pedal).Same, not the bottlehead, but same.
