Paradox916
WIPs sometimes I feel lead to project purgatory and at the risk of cursing this one I’m doing it anyway…
I was pretty excited that @vigilante398 did a full featured Uberschall project and jumped on buying the board as soon as I could, but the problems with me and pedals is they almost always live on the desk and never touch the ground or get stomped on, I play sitting down in front of a DAW with headphones and this has led me to be more and more curious about a rack rig. You don’t really see a lot of DIY projects of this nature, so I figured this would be a good one to see if I actually like the flow of a rack format.
so let’s spin the wheel…
I can start this with pics of an unpopulated and then populated PCB but I think we are past that… It took some time and digging but I found a “cheaper” 2U rack case (I say “cheaper” because even the cheapest ones I found still added a significant amount to the price of this project.) and started laying out the vent holes.. I wanted to do something a little more fancy but it’s a steel case and that’s a lot of holes by hand… so F that
.. we will go with functional.
Not my best but it will work just fine.
4 tubes are going to put out some heat. And I needed to figure out how to mount this PCB
I came up with m3 standoffs and nylon washers to clamp the board and it worked out not to bad…
Because I maybe want a remote foot switch I had to think of something else and abandon the Idea of the standard 3pdt stomp daughter board so I decided the PPCB DPDT latching relay with a little out of the box wiring might work…
In to deep to quit now.. to be continued…..
