8stringalchemy New member Oct 22, 2022 #1 I'm buying parts for my Caesar build and there's no voltage ratings (just sizes) listed for the capacitors. Is there a lower limit I should be keeping to?
Robert Reverse Engineer Oct 22, 2022 #2 It's strictly a 9V circuit so 16V gives a safe margin. Anything higher is fine, just be aware of the physical size.
8stringalchemy New member Oct 22, 2022 #3 Robert said: It's strictly a 9V circuit so 16V gives a safe margin. Anything higher is fine, just be aware of the physical size. Click to expand... I figured, but I'm building another 9v circuit that says "25v minimum" on all the capacitors so I figured I'd ask.
Robert Reverse Engineer Oct 22, 2022 #4 Which project? That's usually the case for circuits with a charge pump or that are commonly run on 9 - 18V.
8stringalchemy New member Oct 22, 2022 #5 Robert said: Which project? That's usually the case for circuits with a charge pump or that are commonly run on 9 - 18V. Click to expand... MBP SludgeHammer
B benny_profane Well-known member Oct 23, 2022 #6 The Sludgehammer can be powered with 18v input provided the components are rated accordingly (i.e., the 25v in the doc).
