Robusto Active member Dec 24, 2020 #1 Greetings, Just finished this pedal and I have silence on the right hand side of the blend knob which means no effect. Is there a schematic?
R rmfx Active member Dec 27, 2020 #2 Ok, so things are working through the input and out. 4558 path is fine. Are the BBD's legit? Are they put in the correct way? Does the rate LED pulse? Transistors in the correct direction? Got any pics you can post? Upvote 0 Downvote
G Gordo Well-known member Dec 27, 2020 #3 Is it boxed up? Mine had the same issue but worked out of the box. Ended up being a pot shorted to the body of the one in front of it. Upvote 0 Downvote
Robusto Active member Dec 27, 2020 #4 BBDs came from Small Bear. Rate led works and changes speed when rate knob is adjusted. Unboxed. https://imgur.com/a/moD93xY Upvote 0 Downvote
Robert George Cloney Dec 27, 2020 #5 Have you tried turning the trim pot back and forth? Upvote 0 Downvote
Robusto Active member Dec 27, 2020 #6 I swear, sometimes all it takes is for me to post here and suddenly the problem magically becomes apparent. Just pulled the BBD chips to make sure they didn’t have any bent pins...they were both the same chip. Problem solved. Thanks! Upvote 0 Downvote
Robusto Active member Dec 27, 2020 #8 Word to that...and I already love it more than my JHS Emperor. Upvote 0 Downvote
PapaBear Well-known member Dec 27, 2020 #9 Robusto said: Word to that...and I already love it more than my JHS Emperor. Click to expand... Don't forget to edit post "solved" Upvote 0 Downvote
