Cameltoe 3pdt switch breakout board & series switch wiring
RICHB555
I’m planning on making a Cameltoe clone with a 2 in 1 Aion Karkadann (Green Rhino) and Ample Alpaca (Red llama). Two questions: 1. Will connecting the Aion and PPCB 3pdt switch breakout boards for traditional 2 in 1 wiring per the wiki work ok given the Ample Alpaca is true bypass? 2. Can anyone advise how the series toggle is wired on the WH Cameltoe? Thanks!
See post #4, Brett has covered what I think you're after.
Additionally ...
DIYSB may be has a fragment of info:
Cameltoe MKII manual pdf:
If you ignore the bad wiring, it works based on a series/parallel switch from a Marshall JTM clone I built a while back. Only issue is that it will oscillate when it’s in parallel and I think the tube screamer is turned on. So that may be a flaw of my wiring.
I was going to work up some more parallel-series switch ideas before posting the following diagrams based on Brett's Post here, but I ran out of time for the others...
This may be of help?:
a-b-series-parallel-loop-switchers-png.91288
