Check my diagram? Series/parallel switch
Pauleo1214
Hey y'all. I am planning one of my stupid combo builds with circuits in parallel in the send/return loopnof a buffer. I want to include the option to switch the two pcbs to series.
Would the wiring in the diagram below work? Any input and verification would be appreciated! DTDT-Switch-2S-Battery-parallel-Charging-series-use.jpg
I'd like to try to help here, can you confirm that this is what you're trying to achieve?
You'd like to go from this:
To this:
On a DPDT ON-ON switch, is that correct?
Cool, it's actually pretty simple.
You'd wire your switch as follows:
Pay close attention to the tags, the I/Os for the effects are re-ordered compared to the previous images. Switch pins are labeled in the schematic.
You could optionally add an indication to the switch setting by going with a 3PDT as follows:
