Can I tent/combine any of these values to make 750R?
EisengesisFX
The ONE component I forgot to order for this Dung Beetle build is a 750R resistor. I know with tenting resistors, you can get within ballpark range of the desired value even if it's not the EXACT number. Can I do that sort of thing with any of the values I have on hand, listed here?
270Ω + 470Ω gets you to 740Ω
In that spot in the circuit the value isn't super critical though, anything in the ballpark should be fine though, either 680Ω or 820Ω should work without issue.
Graphic from another thread; Just sub in your values:
270Ω + 470Ω + 10Ω = 750Ω 🔔🚨🎉(y)👍
477r-resistor-bridge-png.85341
When something similar happens to me, I always blame sleep deprivation — and in all too many cases, it's absolutely true.
Do you partake? Maybe tipple a little? Those are good for blame deflection, too. 😜
Here, I finally had a moment to update the Resistor-Bridge to be specific to EisengesisFX's quandary:
I put them in ascending order of value from left to right, I hope this is an acceptable format.
And for those who don't want to be locked into those values, and diagram to be used in future with alternate values if required,
here's a (to coin a term) ...
NON-DENUMERATIONAL RESISTOR-BRIDGE:
While we're at it, because the OP provided so many options (ie resistor values) to play with, let's muck around with parallel and series, too:
Many roads can lead to 750 Ohms. 🤷‍♂️
