Now that one's too small. PedalPCB limits picture size to 1MB. Some folks use Google Drive or imgbb.com to host pix and then link to them. I suspect that Q2's hFE is too high. Can you try swapping in another one? If can you post a higher-res pic, we'll check your resistor values. Try measuring Q3's emitter voltage. It won't change much when you turn the trimpot.
I usually don't have a problem posting pix here because I do a little photo editing to crop out background stuff and reduce the file size.
As a temporary fix, you can tack in a 10K - 15K resistor from pin 1 to pin 3 on the FUZZ pot. That will bring the resistance Q3 sees back to someting close to 5K.
Check the voltage from C to E on Q2, it might be saturating.
tacking the 10k across did it! it still has a gated sound no matter the voltage setting. could this be too hot Hfe on Q1,Q2? Or is this the characteristic of this fuzz?
That's where it should be.
I dunno, maybe it's supposed to sound that way. Is it gated at all FUZZ settings?
Let's check one more thing:
Measure the emitter voltages on Q2 and Q3 (separately). Q2 might be close to cutoff.
