Travis
I did a pedal like charlie brown v4, it´s sound perfectly but I can hear a permanent noise like a cricket.
CRICKET.mp3
drive.google.com
I Will try another oneAre you are getting the noise even with nothing plugged into the input? Do you have a different power supply you could try on this pedal? Some pedals are more sensitive to noise from a supply than others.
YesAre you are getting the noise even with nothing plugged into the input? Do you have a different power supply you could try on this pedal? Some pedals are more sensitive to noise from a supply than others.
The cricket sound gett Up with volume and when Gain is full up the crickets sound is very low but still there.Or try a battery. Single-ended circuits like this one have pretty poor power supply rejection. There really should have been a resistor in series with D100. Does the cricket noise change if you turn the DRIVE control? If you have an audio probe, try probing IC1-7. There's a 100uF cap (C17) on the output of an opamp, which IMHO is very bad. It should have been on the input side of IC1.2. If you get noise on IC1-7, try removing C17.
I Supersized your Photo, I don't know if this is what you Hearing?The cricket sound gett Up with volume and when Gain is full up the crickets sound is very low but still there.
The noise still there with all the suppliesI Supersized your Photo, I don't know if this is what you Hearing?
Ha Ha, I couldn't Help myself. I've had this with a few pedals & it's usually a miss match with Power supply or another Pedal.
Are you Daisy chained, Try using single power supply.
As Chuck said, try a Battery!
It's a process of Elimination!!!
If someone has built this, Chime In.
Yes the noise comes from the pedalalso -- I understand you hear the noise with nothing plugged into the effect. have you tried removing the cable plugged in to your amp and testing with an audio probe to see if you still hear the noise at the output jack?
The noise still there when it's closeTry a battery and if the noise is still there you can eliminate the power supplies as a possible source of the noise.
Also -- I know the effect is in the case, but are you putting the back on it when you are testing it for noise? If not, try it closed up as well since that might provide a bit more shielding.
Ok I Will tryLet us know if you hear the noise when it runs on a battery. If so, it is probably haunted.
Try another TL072 Op Amp, or JRC4558D, OPA2134.
I did, with TL072, 4558, 4559, OPA2134...Try another TL072 Op Amp, or JRC4558D, OPA2134.
