carlsoncoder
I ordered some SMD J201's for use in the Chop Shop project. In order to make it work on the PCB I got some SMD adapter boards...never soldered SMD but I'm sure it'll be a fun one
The question I had was on the layout - the breakout board has pins labeled D, S, and G (Drain, Source, Gate). I looked at the datasheet for the J201 (https://pdf1.alldatasheet.com/datasheet-pdf/view/53142/FAIRCHILD/J201.html), and I think I know which is which, but wanted to confirm.
If I'm looking at the Chop Shop PCB (https://www.pedalpcb.com/product/chopshop/), going from left to right on the J201's, would it be "D", "S", "G"?
Thanks!
Thanks!
