Did it, no change unfortunately
Going to try and swap it when I get the chance
My shitty DMM doesn't have a continuity tester but tried it with resistor tester and looks like there is no continuity. I hope to solve the popping with a new 3pdt
But the squealing isn't going away![]()
It's a 2N2222A, I think I have put it down with the correct pinout as I remember reading on the forum about the different layouts for the two different transistorsView attachment 55691
What type 2n2222 did you use?
Note Direction of transistor per part number:
good idea, I'll try this to see if it solves the squealing, if it does I'll replace the switchIf the switch is fried it could be shorting out internally in all sorts of weird ways - might be contributing to the squeal? I don't think you'd be able to test continuity the way @music6000 described if you have the PCB attached - I don't know what wiring scheme the ppcb breakout boards use but if you could figure that out you'd be able to test it.
The easiest thing to do before going to the trouble of fully replacing the switch would be to disconnect it, and just wire the IN and OUT on the effect PCB right to the jacks, bypassing the switch all together.
Kleins are expensive here I'll definitely buy a better oneAlso, you deserve a better DMM! A decent Klein / Uni-T / AstroAI model is like $30 and will let you test a bunch of things.
I'll take a look when I'm home from work... Do you know what values they should be?Might be out of spec JFETs in that case - what voltages are you seeing on the fet pins?
I got them in a kit from Musikding... I remember reading another thread here where the pedal squealing was solved by using SMD JFETS, I might have to give it a go with daughter boards.This is very picky about J201's being within the required IDSS.
Where did you get your J201's ???
From the Builder, Thanks Guillaume - FC :
Let's start by sorting the JFETS. As we saw on the datasheet, J201's can have an Idss value from 200uA to 2mA. That is a huge range. For Q1, you want a J201 that has an Idss from 600-800 uA. For Q2, you want one with Idss about 400-600uA.
So you'll have to see what you have to work with. You might be unlucky and have all J201's with crazy values like 1500uA. In that case, the drain resistors will need to be changed.
Big +1 to using MMBFJ201I'll take a look when I'm home from work... Do you know what values they should be?
I finally had time to do some testing, without the switch.A quick unscientific test you can do is touch the transistors with your finger to see if that dampens the oscillating that may lead you to the culprit if it is an oscillating transistor
With 2 and 3 joined on the sag pot you'd increase resistance across the pot as you turn it CW have you tried adjusting the trimmers whilst it's squealing
As you'll know fet parameters even from the same lot can vary wildly so might be worth a shot
you know, that could actually be it. Lately my solid state Fender 85 started popping loudly when I turn it off... Tomorrow afternoon I'll try pluggin into my old practice amp.What is the pedal plugged into? Popping can often be caused by DC leaking out of the input of an amp.
Looks like this is it. When I play during band rehearsals it is fine, when I'm home it pops so I'm thinking it's my ampWhat is the pedal plugged into? Popping can often be caused by DC leaking out of the input of an amp.
Hi all
First PPCB build, the lovely Chop Shop.
Biased the J201 without problems thanks to the threads in here, sounds great, boxed it up and it pops quite loudly when pushing the 3pdt.
Anything obvious that I'm missing? R1 should be the pull down resistor right? Looks fine to me
do I have the V1 board?V1 didn't have a pulldown resistor on the output.
It might be worth adding a 10K resistor from the OUT pad to GND.
People smarter than me. If this is the case, is there anything design-wise in a pedal we can do to avoid it? Like are certain designs more or less likely to be affected by this? Or is it 100% the amps fault?Looks like this is it. When I play during band rehearsals it is fine, when I'm home it pops so I'm thinking it's my amp
