mrguep
Hi there,
I recently build a circulator kit ordered from Musikding, and as usual (or maybe I'm unlucky) there were some missing components, in this case, the LM13700 where not here.
So, tired of waiting for thoose now rare IC's, I've checked for a LM13700 substitute and NE5517 seems to be a good candidate (AionFx tells that it's the same parts, just different manufacturers -> https://aionfx.com/component/ne5517n/ )
Also, I did the @Chuck D. Bones mods below (by the way, he did an awesome job, big up!):
8. Added a 3.3Meg resistor (R109) from pin 3 of the RATE pot to IC1 pin 3 (Vref). Along with item 9, ensures that the LFO will always start and never stall.
9. Added a 22K resistor (R107) from IC3 pin 8 to IC3 pin 6. Along with item 8, ensures that the LFO will always start and never stall. 8 & 9 must be done together, I consider them mandatory.
11. Increased R27 to 33K. In the original design, the Circulator will break into oscillation when RES is dimed. I have no use for a pedal that screams at me. With this mod, RES has plenty of range and stops just short of oscillation. Totally optional.
12. Added a Throb LED (R108 & LED2). I think any pedal that has an LFO should also have a Throb or heartbeat LED. I prefer that LED to run all the time, not just when the pedal is engaged. R108 is soldered to LED2 and has clear shrink sleeve over it. Any color LED will work. Do not make R108 less than 10K; if your LED isn't bright enough, get a different LED. Totally optional, but if you do this you need to do items 8 & 9 to ensure that the Throb LED doesn't stop the LFO.
The pedal fires up, throb LED throbes, all pots works, I can clearly hear the effect but there are 2 issues:
1- A "pop" is audible in each "phase cycle". It matched the rate control, it's getting louder when rate goes faster, i feel it's changing with swap control but i couldn't describe it clearly. Here is a record of that sound with rate changing. Resonance control doesn't affect this "pop".
2- Even I did the @Chuck D. Bones mods to prevent LFO to stall or fail starting, when I turn the rate down, LFO stops.
Could thoose 2 issues could be linked to NE5517/LM13700 swap?
Has anyone ever encountered thoose issues?
Help would be really appreciate
Thank you all!
Thank you all!
