Clandestine (Chase Tone Secret) noise increases when putting on back lid
here is a remark from another forum about leaking capacitors that might explain why putting on the back would raise the noise level by trapping the noise that is being picked up in the circuit: Maybe one or more of your caps is picking up noise from your charge pump. Not sure why raising the incoming voltage from 9v to 12v would change anything, but it suggests the charge pump is the noise source.
FWIW, I have seen/heard a hi-fi amplifier with the same symptom. It was the filter capacitors but not what you're thinking. The values measured alright but they had very high ESR and were letting through the switching noise from the high voltage rectifier. The fix was to replace the filter capacitors.
I also tried changing the charge pump from 1044 to 7660s and it didn’t change the behavior.
I will order some higher than 25v elco caps to see if that changes something. It seems not related to the transistor as I swapped these with no change to the behavior.
Another thing I was thinking is that most people put the orange caps in there using the extended pads. I used the inner pads, not sure if the unconnected/open external pads could be influencing something or pick something up?
I have to agree with zgrav with my suspicion still coming back to the 25v electro's, the higher voltage is somehow masking the voltage leaking from them.
I would be looking at 35v minimum, I always use 50v with the 10uf or lower as they are the same size as a 16v Electro anyway.
I have 50v 10uf but not higher voltage 220uf in my stock.
Can I use 330uf or 120uf?
The Aion Ares uses 100uf before the charge pump and no 220uf at the back. Only 2x 1n5827 with 2x 10uf
I don't quite know how the charge pumps work, but could it be that the noise increases to such high frequencies that you can't hear it anymore, when running at 12V?
I'm pretty sure I used the inner pads, at least I used just normal film box caps (and one ceramic).
I think both 220uF caps are in the power filtering section, so bigger ones should work fine. Probably 120uF too, but AFAIK larger ones are technically better (or negligible, but at least not worse), and since you're looking to get rid of noise, might want to be safe and go with bigger ones.
The first 220uf is before the charge pump so can be 16v or 25v
change out the 10u caps first and see if you get any improvement in the noise. if needed, you can then sub in the 330 for the 220 to see if that helps. also don't forget to touch up the connections on the film caps. you can use your meter to make sure the inner tabs are connected to the outer tabs for those if you want to confirm they are properly in the circuit.
Replaced all 25v+ rated elco caps with 35v and 50v and reflowed the film caps. The noise problem is still there on 9v but now I can safely use it on 12v and will keep it like that.
I’ve recently build an AION Ares and rehoused the Clandestine I build which I removed from the enclosure.
I removed the zener diode as mentioned by @Robert to try, and it’s removed the static noise issues on 9v.
I used the same caps as the Clandestine for the switch on the Ares (thanks @Big Monk for the tip) but it somehow sounds darker than the Clandestine. Not sure how much the buffer/2nd gain stage causes this? I made my own Trimmit on Vero and used a 50k trimpot and noticed that I can’t get the 2n5457 I have in Q1 lower than about 13,7v. Will need to experiment with others I have.
I used a J113 in Q2 and when I replace that with a 2SK30A it sounds a tiny bit brighter.
