finebyfine
You could also use the unused op amp to buffer the VR rail or to implement an active tone filter
Would that look like this? From a different circuit but I think this is what you meanYou could also use the unused op amp to buffer the VR rail or to implement an active tone filter
Yup!Would that look like this? From a different circuit but I think this is what you mean
This - I'd recommend a Sallen-Key type LPF, the Prunes loves heavily low passed signals.
It also loves being driven by suboctaves
I'm curious to see/ hear the results with the Timmy front end, but I've a feeling it'll be kinda underwhelming. It's neither filtered heavily or particularly harmonically rich enough, in my opinion
Off the top of my head, the Op-amp Big Muff uses one pre-clipping for that warmer fuzz texture, and the Octarock uses a few at various points to aid in trackingThanks. Do you have an example of the Salem key in action? Or know how i might implement it here? I’m a bit of an amateur with theory.
Open to other overdrive ideas if you have any? Timmy was chosen mostly because it’s simple.
That is awesome. I kind of want to take that circuit and throw it in a stompbox. I’m assuming I’d need some sort of charge pump or converter to get that +15 -15 vFor what it's worth, the wavefolder section of the Prunes & Custard is adapted from a design by Juergen Haible (alt link). Digging into that might come up with people who have done similar stuff based on it as well.
I love the fuzz/op amp big muff idea!
I think I will stop tinkering with the idea and just bite the bullet. As long as it works I will be happy even if the Timmy isn’t interesting.
If successful I might look into a more appropriate overdrive or a fuzz like you suggested. Probably the fuzz!
Here is where I am at so far, I have fixed up things that seem to be issues. I will read through those wavefolder documents, I am very interested in the shape poteniometer, hopefully I can include one.
I'm glad there is enthusiasm for this and it's not just me.
Since I suck at breadboarding, I'll have a PCB made of this fairly soon and see how it goes. Fingers crossed it works. I'll post my results, even if it is a total failure.
