Curds and Whey
Nic
It's been a while since I posted a build report. It's also been a while since I've taken the time to spend some time at the bench.
This build has been laying on my bench for at least 3 months, fully popuulated, everything inside the enclosure only waiting to be wired.
So last night, I started wiring things. At first I had a low bezel that was protruding way too far inside the enclosure and hay a blue led that did not satisfy me. So I pulled everything out, installed a yellow led in a new bezel, skipped testing the led before closing everything. Of course the led leads are touching, but I'll leave it for now. When I first powered it, I thought I would have to troubleshoot, but every control works as they should.
The build was very smooth, I did not know what to expect from that pedal and like the sound. Do I have any use for it I'm not sure, time will say.
I won fig's gift card more than a year ago. The enclosure was part of my purchases. I took the curds theme for inspiration and made it local.
Hot & Tasty indeed!
I was going to name a pedal "Poutine", but not only did you beat me to it, you chose the perfect circuit!
Reactions: Nic
