jwyles90
Hey all!
I just finished up this Lectric FX Dandy Horse build and am a bit stumped by it at the moment. Hoping to get some guidance from you all, if possible. I'm running into some issues on the biasing section.
Initially, I was able to get 500hz and 125hz readings from the test pad. When I went to audioprobe test pad #3 though, I wasn't getting any kind of audio signal. I tried switching out IC 3, and realized that I had forgotten to solder BOTH jumpers into place (only had one under the chip). After installing both I'm still not getting any audio signal from the bias 2 test pad portion.
I'm not entirely sure where to go from here. It seems like there's some kind of issue with the chip, but I don't know what that would be, so any help would be greatly appreciated!
