Hey, this is a first time build (second really as I brought a DIY kit and messed up the soldering, using the kits schematic), at the testing phase currently before adding in a switch.
The issue - I don't get a signal when I put power into the pedal, I either get a high deep sound or its dead. I get a signal through the pedal when not powered though.
I have checked over the circuit with a multi-meter, I'm not sure what readings I should be getting, but I'm getting power to all components.
I have changed from a plugged in power supply to a battery with the same issue.
I have also made an audio probe and when the pedal was powered only got signal from the Input to the transistor (Q1) and then only a crackly signal from resistor directly above it in the circuit (R4). Nothing from the rest of the circuit.
Please find pictures below and the schematics I used as a guide.
Thank you for your help.
