DBA Space Ring vero tranformer question?
drgonzo1969
I'm just about done building the DBA space ring on vero board but I wanted to get some clarification before I soldered these tranformers in. Should these be installed primary on the left? here is a link the layout.
Looks like you want the primary on the left. Pin 2 is disconnected in both xformers, and you can see the corresponding cuts in the vero.
actually, if you have room, might be better to bend them 90 degrees instead - gives the xfmr a little more mounting stability.
