DC 2.1mm Jack issues?
2204Stuff
anyone have issues with these from Tayda?
so far they seem solid.
I have had an issue with the plug not being pushed in all the way a couple times, seemed as it was all the way in.
Thanks,
Thanks,
I don't use these from Tayda but something similar that I get off Amazon. (Probably the same mfgr.) As Bricksy said, the genuine Lumbergs will also not seat completely sometimes. This has to do with how tight you tighten the internal nut. When you tighten it, the plastic sheath will bulge slightly not allowing the plug to seat all the way until it's been inserted a few times. The alternative though is to leave it loose enough for the plug to seat but then the jack has a tendency to spin when you plug and unplug the power. I hate when that happens, so I just crank mine down pretty tight.
