Where are you located? Have you checked Mouser?
OPA2134 is a very high-fidelity opamp that is optimized for audio use. If you can't get those, I recommend TL072 as a sub. Because of the high impedances in the first stage, a FET-input opamp is mandatory. It won't be a Delegate clone anymore if you sub a different opamp, but it will be close.
Have you checked out the Boneyard Edition?
