Hi,
The drill templates for my boards seem to be a few mm smaller than they should be. Measuring by placing the PCB over the template. The drill guides should align (at least horizontally) with the potentiometer pads.
I suspect it has to do with some conversion between paper sizes (I have A4 paper). I opened the PDFs on Inkscape to force 1:1 scale printing. It didn't work.
I suppose I could bend the potentiometers a bit, but one of the PCBs has multiple toggle switches (Crunch Capitain Deluxe) and they are mounted flush to the PCB.
I found some templates with dimensions here in the forum, but they don't match my PCBs.
Are this dimensions listed somewhere? I don't mind making my own template, since I'll be doing a dual build.
Thanks!
EDIT: The boards are: Crunch Capitain Deluxe, Bootleg Overdrive and an Obsidius Preamp
Thanks!
