I'd try leaving C12 out don't jumper it just leave it out
@Chuck D. Bones posted somewhere how to calculate a rough voltage doubler output can't find it at the moment, but afaik you count the number of caps coming off IC1 pin 2 and add 1 then multiply by the voltage in and subtract the voltage drop across each diode
So as it stands 2 + 1 = 3 x 9 = 27 - 2 = 25v
(According to the datasheet a 1N5817 drops 0.45v so say 0.50v x 4 = 2v) you'd also get a wee bit of voltage loss from the 1054
Take away a cap and
2 x 9 = 18 - 2 = 16v
Now I don't know if it'll work so I'd try it with the switch left in the 9v position then check what voltage you get on the cathode of D4 before you switch it over and let it loose on the circuit
The analog devices datasheet does show you building blocks etc if you want to have a look
Mind you might be fun watching a few caps blow
Maybe Chuck will come in and tell me I'm an idiot talking a pile of u know what
Just in case.... tell me something new Chuck I already know I'm a chancer but I'm an idiot that likes to learn
Found it scroll down a bit
I’ve just recently built the Triangulum build. It’s a working build but something sounds off. When I turn the level up to a decent level or about half way up I get a really bassy heavily saturated sound that starts to cut out and break apart when heavy power chords are hit. Like it’s being...
forum.pedalpcb.com
