bengarland
I'm a total newbie at building pedals. I built the CaptainBit, SuperHeterodyne, and Arcana successfully but I just finished the DuoPhase and when I plugged it in it blew the 220uf cap at C20B. I had my guitar plugged into the switched input and the output next to it went to my amp (green arrows on photo). Nothing plugged into the other jacks.
----> Image here
----> Here's the build doc for reference.
I noticed one anomaly with the specified layout, since apparently both sides of the board are supposed to be the same -- I'm wondering if Mr. PedalPCB can comment... the resistor pairs of R38A+R46A are flipped compared to R38B+R46B. But on the schematic it looks like they are supposed to be the same on both sides. Is this intentional? I populated it according to the values printed on the PCB and the PCB layout on the build guide. This seems to be the only pair of parts that aren't the same on the left vs right side of the PCB.
Could that be the problem? (I would think not since I'm sure other people would have reported it by now...)
I plan to take it apart and check everything again, but I'm wondering:
1) Is there anything that's "most likely" (such as... a short somewhere?) to cause a capacitor to pop? Let's assume that I have populated the parts correctly on the board.
2) What's the chance that this has totally screwed up my entire board? Like let's say I find a tiny solder bridge somewhere that's the problem, fix it, and replace the cap... (and nothing else is wrong)... what are the chances that it will then work fine?
----> Image here
