Heck, most want a 1590AI will never understand why everyone needs everything in a 125b
Hey buddy, I only need one, and you got four
I've never tried building any of the Madbean projects. Not that I don't have trust in them but I kind of got used to the PedalPCB layout.I’ve built the Madbean one. Sounded great, but it was a pain to put together. Needed the stubby lumberg jacks and even then it was a tight squeeze in a 1590bb. Aesthetically speaking, my ocd hated that the switch didn’t line up with the knobs. I also put the rate LED in. Which is when I found out I don’t care for rate LEDs blinking at me.
I’ve got the Byzantium on the work bench now. Pretty excited to see how it sounds. Hoping it should do everything an electric mistress can do and then some.
You’re doing yourself a disservice. Madbean makes great projects with amazing documentation.I've never tried building any of the Madbean projects.
One of the old discontinued Madbean freq analyzer PCBs, or something else?Wait till you see my frequency analyzer build!
This^^^ You can build more than one, it’s cool.You’re doing yourself a disservice. Madbean makes great projects with amazing documentation.
Brian was doing it before it was cool, or so the website says.Brian is OG, people don't understand Jimi. Brian is King.
You convinced me ... it's worth experimenting!You’re doing yourself a disservice. Madbean makes great projects with amazing documentation.
Looks like you got them from Jawas
The e-lady I believe is based on the DELUXE electric mistress that was released in the late 70-early 80s. They had a more metallic deeper sweep and wider frequency range. The Madbean current lover is a 9v to 12v recreation of the V1 which is a little brighter and more musical with a shallower depth. Depends on what sound your going for. V1 is Gilmore, Deluxe is Robert Smith.
Got one myself. Also got the Ninety Script which isn’t bad either. Most of the Mooer mini pedals are good. Not really a bad one in the bunch. They cheap for sure. Can find better…but still cool to get for stacking.I'm gonna throw this out there: I love my Mooer E-Lady. It's a great pedal that captures ALOT (not all of course) of that Electric Mistress magic. And it's cheap. They can be had for $40 all day if you look around.
If you are not familiar with the Mistress sound, try the E-Lady to see if you like it. A circuit that is truer to the OG Mistress will be brighter than the E-Lady but the hallmarks are there.
I plan on making the Madbean Current Lover because I'm a EM convert because of the E-Lady
Lectric-fx is releasing a deluxe version this spring/summer and I'm all over it. It was announced last year that they were going to work on it. The time has come.
I have to correct you here, the madbean is a recreation of what's usually called the V6, which is a 9V lower noise redesign of the original 18V electric mistress, the e-lady is also a copy of this unit (as are the Hartman and most of the mistress clones out there).The e-lady I believe is based on the DELUXE electric mistress that was released in the late 70-early 80s. They had a more metallic deeper sweep and wider frequency range. The Madbean current lover is a 9v to 12v recreation of the V1 which is a little brighter and more musical with a shallower depth. Depends on what sound your going for. V1 is Gilmore, Deluxe is Robert Smith.
Yes, the 70's model.A version of the big box deluxe?
The re-issue EHX deluxe electric mistress (using the R5106) is also basically a V6.
The vintage 70s DEM is a 15v design with the same basic LFO/Clock design as the 9V mistress but giving a much wider sweep range while the audio is totally different, not as bright as the smaller box mistresses but yes, a bit more frequency range.
The 18V V1 is rarely ever cloned as it ticks by design, is finicky to clone and horrendously noisy.
Well hell yeah there is, you need both!So if I own the E-Lady already, is there a point in having the current lover as well? If they are cloned from the same circuit?
I imagine the build quality would be more robust but I love the E-Lady as it is so I would t want to search out a chip set for a pedal that’s going to be similar to what I already have.
The current lover has an option for an effects loop, you can fully adjust the feedback and it has a volume trimmer inside. Worth the build. Plus as you say more robust.
I can't claim they're exactly the same as I haven't seen the schematic of the E-Lady or directly compared them, but probably pretty close in sound, yeah...So if I own the E-Lady already, is there a point in having the current lover as well? If they are cloned from the same circuit?
That reminds me, the output boost he added, that 220n/10k is going to end up cutting some bass from the signal and make things thinner than necessary... I'd make them 470n/22k to still get a decent range on the output trimmer.The Madbean current lover is a which is a little brighter and more musical with a shallower depth
