Electro Vibe Build Report Video
Great job. Very nice build and thanks for explaining your settings.
I also noticed that the Speed range is not wide. I'd like it to go much faster with the knob maxed out.
Is it possible to widen the Speed range by changing some of the component values and if so how?
I have experience making Phase 90 from BYOC. BYOC's Phase 90 kit have 6 of UA741 opamp chips and speed is so slow. I changed opamp chip to LM741 and speed is more fast like any other Phase 90 pedals.
Can this method be applied here as well?
Check out the build doc for the madbean harbinger. The notes tell how to modify the top speed
R14 and R15 to 2k7, for faster speed
I tried already this Mod on Photonvibe. If you change both resistors, speed is much faster than before. However, the speed knob response is delayed. When you rotate the speed knob, speed will not change immediately.
Both 4.7k resistors are R14 & R15.
