On the board above the LT1054 and 47R there is a shape like a transistor with three holes no label. In another thread I saw the shape labeled as IC1. Since there is no build doc -
What component is this ?
I am not familiar with that component.
Or I should say ordering the proper component. I know what a voltage regulator is but not the specific one for the ElectroVibe circuit.
I have the board finished except that component.
Thank You ! ! !
Who is a good source for 7532 photocells ?
I have heard photocells are as finicky as
germanium transistors.
How are you choosing/calibrating them ?
What are the best/acceptable measurements ?
The 7371 bulb from Digikey hits the lid of the 1590BB enclosure. I saw another member had the same problem. There is no place to gain space. The Dual pots are snug with the board.
Solutions ?
1. Different bulb - is a 7219 compatible performance wise ? Or another ?
2. Different enclosure - Tayda 1590BB2
No extra washers. Lid will close.
But touches glass bulb. Just thought perhaps
not a good situation. ? ? ?
By the way Big Monk I have read several of your threads … and enjoy them very much.
Thank You !
I’ve thought about finding a way to use phototransistors in a circuit, but I still don’t fully understand them. I’ve thought about testing out photodiodes as clippers in the second clipping stage of a circuit with two clipping stages, with led used as the clippers in the first clipping stage. I still don’t fully understand photodiodes outside of a light-measurement circuit (ie, I have no idea how to use photodiodes outside of a textbook application), but a few quick tests I did a few years ago did suggest that they work as clippers, albeit in a pretty strange and potentially undesirable way.
Just curious -
For the Electrovibe which voltage regulator is better for the circuit ?
1) Current Quiescent 3 mA with PSRR 51 dB
2) Current Quiescent 6 mA with PSRR 39 dB
Thank You !
