leadfoot
I am currently wrapping up an ElectrVibe Mini build and ran into the problem with the LFO not starting up. I can manually cause the bulb to increase in intensity via the gain and bias knobs and hear a change in the tone (as you'd expect in a Vibe), so I know the rest of the circuit works. It is just the LFO section that does not work.
The only modifications for the LFO circuit are:
r14, r15 - 1.5k
c8 - 2.2uF
I'm suspecting I might need to switch to tantalum capacitors as it appears to be leakage related as the potentiometers work as expected (tested via DMM resistor measurement), joints all appear to be fine as continuity appears ok.
r14, r15 - 1.5k
c8 - 2.2uF
