I really like the warm white LED for the application. Where did you end up soldering your ground for the rate mod?
Very nice!I did the unity mod at R4, the darlington mod at Q14, the reliability mod at Q3 and Q4, the low range mod at R12 and C8, the high speed mod at R14 an R15. then the 50k trim pot with 68ks at R16 and R17, and the 10uf mod on the series caps. Oh and tantalum on C7, 8 and 9.
I did my lights slightly a little different. I noticed that I could wire the rate led set up on both sides of the R19 resistor, and then I put it in place of the speed led. Basically because it shows speed. Then i used dpdt switch on the chorus/vibe switch so I could do the bicolor to indicate chorus or vibe settings.
I had a lot of fun building this and it sounds pretty awesome!
TBH always-on blinking LEDs are annoying![]()
So question for the phase mod on R16/17: what final values are you guys seeing? Are they like a few hundred ohms off of each other or like a few thousand?
Second question: my electrovibe mini has a really strong effect/depth on the vibrato setting, but seems a bit too subtle on the chorus setting. Will the phase mod likely improve this? I've messed with the bias and offset ad nauseam and am pretty sure I have that as dialed in as possible to maximize the depth.
Gotcha. So do you think to improve the chorus side I should perform the mod or keep trying to tune the lfo?
Gotcha. Like I said I've tried everything with the LFO. Anything else I could possibly be missing? Possibly my expectations are out of line.Tune the LFO. 100%
You definitely can’t have it both ways, i.e. you can’t have strong vibrato and strong vibe.
The phase mix is like a last 5% type mod.
Does anyone have a good video of their LFO on a pedal they are happy with to give others a reference/starting point of what we should be shooting for? Would be supremely helpful.
Hello, i'am tweaking my ElectroVibe build chasing that Throb effect one big difference to original univibe i dont know why they have mistake in both schematic and BOM.... They powering whole signal section trough L75L12 (12V) and it should be by my opinion 15V thats where even schematic is wrong... L78L12 in schem and it shows +15V output from that regulator! So i believe that there should be L78L15
Next.
I wonder why you use those 2.2uF tantalums ? Wou wont get as much sqeak as bulb is drived ? I thought that tantalums are not much good for audio purposes... https://www.coda-effects.com/2015/04/capacitors-which-one-to-choose.html.
Yeah, i'm not using LT1054 but step-up module to push 9V 1A in to 18V then trough regulator now 7815 and i noticed biiig improvement in woble. But even that i used L7515 the power consuption is still around 100-120mA. Now i try to swap out those 2n5088 which are probably fake bcs they're all around 650 hfe and original transistors were around 350 hfe.There’s not enough of a delta in the supply voltage to properly regulate at 15V using the L78L15. That’s why the L78L12 is used.
Leakage is the issue per my talks with @Chuck D. Bones
You need low/no leakage/residual resistance in the LFO caps for it to work it’s best.
Also, those caps aren’t in the audio path, they are in the LFO.
