This one doesn't cut corners or introduce much in terms of progress. It simply displays what the original was/is.
I’ll try and test it on my build this evening and let you know.Anybody know the current draw for the Electrovibe? I don’t have any taps greater than 100 mA on my two power bricks anymore.
Yeah mine is on a 100ma supply.What are you running it with? If it will run on a 100 mA tap, I’m good. If not, I’ll need an external supply.
Understood. Just out of curiosity, what was the trouble with how the indication worked out? Wouldn't you just assume a color for each speed control, i.e. Speed 1 = Red and Speed 2 = Blue?
Would also be cool to have an LED next to each speed knob.If I had it to do over again I'd probably leave the bi-color LED pads in place and let the builder decide.
Thanks Cooder. The original, besides being the size of a loaf of bread, had a slight drop in volume. I think because it had a tendancy to drop a tiny bit off the top and the bottom frequencies it was likely more of a perceived volume loss. The pedal was a bit hissy, although hardly a deal breaker. I always liked it early in the signal chain so that it became a bit more evil sounding than "effect-y". The coolest part was that the LFO was kinda lumpy in a way that I haven't heard many clones capture.Excellent and thanks for the details on lamp ldr placement and stuff.
As I have never had the chance to play an original, what do you mean exactly with 'coolest parts and shortcomings of original'; would love to hear your take on that a bit more in detail. You mentioned noise being an issue?
