For this one I just drilled a single oversized round hole for each slide switch assembly. I need to check the size, but I used one of the larger stepped bits.
You want the hole to be large enough that the entire slide switch assembly (switch + mini breakout board) can fit inside the hole, but not so large that it extends past the edge of the faceplate.
