MichaelW
This would be cool.And helpful for a pedal board that has FF's as well as Delays and other stuff. I could live without the boost. One loop buffered, one unbuffered for FF's.....
Upvote
23
EDIT YOUR FIRST POST (#14)!Hmmm, one thing I forgot, phase reversal. I learned this the hard way when I tried using the Buff n Blend board. Not all pedals like to be blended due to phase issues. So there's got to be a way to reverse phase.
I love this sort of "utility" type stuff!
I've put in a couple of requests for similar boxes in the past. I've made more switchers, blenders, loopers, etc than I care to count. And they all work just fine and are fairly simple to put together, but I would love to see them done on PCBs...In my experience a lot of these are easy enough to build but end up with a lot of wires and such and it's just hard to keep clean. Stuff like board-mounted jacks, pots, etc would make it all so, so much cleaner...
@Feral Feline I bet you could draw up and design this with just jacks and switches....EDIT YOUR FIRST POST (#14)!
Keep all the info together.
I like the meat & potatoes on a PCB, but having board-mounted jacks is a no-go for me. I might want to build this in a 1590BX (or 1032L) while someone else might want to wire up an all in one grab'n'go pedal in a monster oversized Hammond sloping enclosure.
A good example is THCustom's Pro-Cessor, two models are offered — one with board mounted jacks and the other offboard wired jacks.
The board-mounted jacks are in the wrong order (IN OUT SENDs & RETURNs) according to my needs and sensibilities:
In/Out S/R S/R
... so I ordered the one with offboard wiring.
Can wire it however you want:
IN S/R S/R Out
or
IN R R S S OUT
etc.
Sorry I all-capped ehr shouted. Just was trying to be emphatically enthusiastic in my suggestion.@Feral Feline I bet you could draw up and design this with just jacks and switches....
After everyone buys Klein bottle pcbs.
Finally I'll have something worthy of running my two Klein Bottles into ...
Just plug them into each other and be done with it.
