scheffehcs
Hey, looking to see if anyone has built or has a layout for a feedback looper. I’ve heard a phase inverter is handy, any other bells and whistles I could throw in there? Maybe a boost circuit?
the arcade buttons on Amazon are pretty bad. The research I’ve done in the past seems To show that boutique pinball and custom arcade cabinet makers use Sanwa, Happ, or sometimes Semitsu brand switches. Each has a slightly different style to them, but they’re all much higher quality than the No-name stuff you typically find online…they are all much more robust than the arcade-buttons. Kinda doesn't make sense, since a true arcade-button has to withstand constant hammering as people try to defeat the Galaxians, Space Invaders, Centipedes, etc...
Maybe I just got consumer-level "arcade"-buttons...
This is basically the same as Nacht's layout but with a dimmer for the led/ldr. Any Idea on how to add a phase inverter? or other bells and whistles? Feral Feline has some cool ideas in their post but does't show how to do them.
I hope this works. I haven't built it yet
Is it not the same a Nacht's diagram? I looks like the audio signal is going through the LDR on coltonius's layout tooYou have audio signal going through your LDR…dimmered-LED
I'm just messin' around trying to make nasty sounds with my guitar.first I need to understand it and your goals/objectives
My foggy sleep-headed posts are worse than drunk-posting.Is it not the same a Nacht's diagram? I looks like the audio signal is going through the LDR on coltonius's layout too
Someone said they don't like the LDR because its inconsistent depending on what room your in.
Would I be able to make this a parallel mixer too? I would be nice to have that and "ON-OFF ANTI STUTTER — have this patch-bay wired so it can do the whole signal or just the effect"
