Frog Prince (Lot Lizard)
ClippyTheDiode
Here is my Lot Lizard build dubbed the "Frog Prince".
I built it to the "big" box spec so I used a C1K for balance, stuffed C3, and omitted C8.
This is my first attempt at water slide decals on a pedal. Probably would look better on a white background. I may remake the decal in vinyl later.
I love that image for the decal! I've found that if you use transparent decals it's hard to get the color to show up against darker or more bold backgrounds. If you haven't already, check out the decal paper that is on a white background. Makes it way easier to have your colors show up, regardless of the enclosure color.
Good call. I will order some of the white decals and try again.
I had this transparent decal paper already from a headstock decal I made.
