FV-1 stereo PCB availability
Deftaudio
Hi,
I see Binaura Stereo FV-1 PCBs in development state for some time now. Any news on the release? Is there another board that supports FV-1 in true stereo mode?
The board has two buffered inputs, I just use switched jacks to send the same signal to both inputs when only one cable is plugged in.
Rad! I think I have an idea in mind for a way to rig up the switches jacks to also switch the eeprom out depending on if both plugs are used or just one, so that algorithms optimized for a mono input can be used in a mono split situation and algorithms optimized for stereo input can be used when in full stereo.
