Gain and Tone controls do not work in my Kliche mini! Help!!!
OscarA2B
I really don’t know what else to do with this pedal, the volume is low, the Gain and Tone control don’t seem to make any difference! I have tried to replace the ICs, checked all the parts individually, replaced some resistors but still nothing happened!
I replaced the Jacks just in case as well, the bypass works good but when I engage the pedal, I have to roll all the volume pot all the way up to get some volume but that is it, not gain or tone changes!!
Any one could help me with it please?
i'm not familiar with those particular jacks... so i'm no help there... I do see some of your soldering isn't wicking to both sides... you could have a cold joint.... unbox it and go ahead and touch up your joints.... and does your led work?
@OscarA2B I would test the controls outside the enclosure. Make sure the pots are not shorting on any solder pads. I don't see a dust cover or electrical tape on your tone control.
Yes, I do have electrical tape under the tone control, just removed it to take the pic so the soldering could be visible!
I dont get why I still have a little amount of volume but nothing else happens.
electrical tape is not a good idea... the leads can just poke through and short..... hook up power to pcb outside the enclosure.. bend the treble pot off the board and test for signal with all controls
I know you said you checked your parts, but I’d do another pass looking for a multiplier error on a resistor somewhere - 470k that should have been 47k etc. that would be my first guess for what would cause your problem.
On future builds, there is an advantage to sticking to one resistor type and facing them all the same way. Makes reading the color bands much easier when you’re troubleshooting.
Hi, thank you alot for the help first of all!!
This is a quick update. That C3 was really a good catch, I just replaced it with a new one!
I just triple checked all the resistors and capacitors Values and the only thing I found weird is R3 and R30 drops the value after been installed! R3 = 8.9k and R30 =45.9k
They should be 100k! I tested before replacing to get the right value but it just keeps changing values after being installed!
Also I removed the pcb out of the case and made sure nothing was doing a bad contact or connection and tested but same thing!
I check also the B100k dual gang pot and replaced just in case!
I was hoping that C3 was the problem but it made not difference, the pedal still has little volume, the gain and tone pot doesn’t do nothing!
