Gain Pot (Knob) Does Nothing
I decided to build the Virgil today. (Bad monkey! Bad!) Everything works fine other than the gain knob, which does nothing. What I have currently is a limited EQ pedal. Level, low, and high pots all work, but the gain does nothing. The sound is clear and clean.
I resoldered that section of the board to make sure there was good connection. The gain section still does nothing.
I also replaced IC2 with a new JRC4580. Same issue.
(I get the same results inside and outside the enclosure.)
Using a DMM, I checked the gain section of IC-2 (pins 1 and 2).
The resistance (unpowered) between pins 1 and 2 is 9k94
The voltage reading (powered) for:
Pin 1: 5.37 v
Pin 2: 5.32 v
I have no idea if those numbers are correct.
Side note: I noticed that the unit's power draw is 33 mA, which seems to be high.
swap the 4580 for something else like a 4558 and see what happens.
almost everyone that has built one of these with 4580 has had issues.
