Hmm, that one says it's inspired by the lightspeed?I think fuzzdog does one in the UK.
Edit - Here you go
Gainer PCB
Please see the kit page for full description. Power and Signal pads match the Direct Connect 3PDT Daughterboard Inspired by: Gainster PCB size: 50 x 23mmshop.pedalparts.co.uk
It’s weird it says that, the schematic definitely looks like the gainster (except I think the OG gainster uses an 072 and big-ass PIO caps), a bufferless OD-1 with a presence control right?Hmm, that one says it's inspired by the lightspeed?
I think the Red Snapper and Gainster are almost identical. You could build the PPCB Red Herring, or snoop around and find the one or two mods to turn it into the Gainster.
Oh dang they really are. If someone wants to double-check me, to do a Gainster on the Red Herring Board:Hmm, that one says it's inspired by the lightspeed?
Hmm, this page says Gainster: Gainer PCB (pedalparts.co.uk).It’s weird it says that, the schematic definitely looks like the gainster (except I think the OG gainster uses an 072 and big-ass PIO caps), a bufferless OD-1 with a presence control right?
But this one says Lightspeed: Gainer Drive (pedalparts.co.uk)
And they offer another board that is based on Lightspeed, so must just be a cut-and-paste typo on that web page.
Ordered one, thanks!I think fuzzdog does one in the UK.
Edit - Here you go
Gainer PCB
Looked there but it’s no longer for saleDoes madbean still have the Clark Gainster?
This looks correct. I have parts on order to build this and will post a report when done. All I've ever built before are AionFX kits so this might take me longer...Oh dang they really are. If someone wants to double-check me, to do a Gainster on the Red Herring Board:
IC1 - JRC072
R2 - 10K
C1 - 100n
C2 - 120p
R6 - 10K
C5 - 2n2
VOLUME - A500K
C4 - OMIT
CUT - replace with a 22K resistor between pins 1 and 3
And you’ve got a Gainster (the “BITE” is the “PRESENCE” control)
The starting point for all of this is the Boss OD-1.I don't think the Bite or Cut control really eliminate the usefulness of each other. It's not that far off from the bass and treble controls on the Timmy. The controls were kind of a evolutionary process on these dual op amp IC overdrives if you look at the schematics of similar overdrives.
Red Snapper 1996/1998
Gainster 2001
Zen Drive 2004
Timmy 2004
Hoochee Mama 2011
Mythos Olympus 2021
Barber Fuggedaboutit 2023
