Fama
Gatekeeper from Effects Layouts, schematic here: http://effectslayouts.com/wp-content/uploads/2022/05/GateKeeper-Build-Doc.pdf
I get a delay, but it's very weak and muffled. With tone at full it's like a bit crappier version of the dry signal, but quickly devolves to mud, while with the tone lower it's just mud to begin with. Mix at full is ~unity or a bit under.
I've reflowed some suspicious joints, they still look wonky, I'll try to maybe fix them up more and use a solder sucker to make them look nicer too. But looking at the board with a magnifying glass, I can't see anything that looks obviously bad.
I've double checked every cap (and their orientation), double checked all the pot values, and checked about half of the resistors with a DMM until I hit R18 which gives me 44k when the resistor itself is 220k, I think it's just getting a lower resistance through ground maybe? Or is this some sort of an issue? It's identical with the rest of the 220k's in the bag, and those measure 220k. I also tried another TL072. I don't have spare voltage regulators or PT2399's (the JRC4558 is in the modulation part I think, and I haven't even tested that yet).
One substitution, a 330nF and 150nF caps in parallel instead of the 470nF in the BOM, both are just in the same holes.
The PT2399 was the wrong way around at first, but apparently that shouldn't damage it?
There's also a constant buzz when my guitar volume is on, but could maybe be because it's not boxed? Not sure if that's another clue.
Sound sample, mix, tone and repeats are at full here
![DSC_2469.JPG DSC_2469.JPG](https://forum.pedalpcb.com/data/attachments/50/50660-2b2488b409ac66842d3a635ff01818db.jpg)
![DSC_2468.JPG DSC_2468.JPG](https://forum.pedalpcb.com/data/attachments/50/50659-92319f874a9da427c1745e2cb1821ace.jpg)
![DSC_2467.JPG DSC_2467.JPG](https://forum.pedalpcb.com/data/attachments/50/50658-c10cc7a2eb9d814fbcb75046b681fa7b.jpg)
