General perf board question
jdduffield
When working with a perf board where the pads are isolated like this (see attached image), is it best to bridge the solder between connecting pads or is it better to bend the leads over and use that wire to make the connection?
Basically. I've only done one perf build, a silicon npn ff. I ended up making traces with spare bits of clipped leads along with the component leads. Though requiring more auxiliary materials, I kinda just prefer etching for single sided boards. Even more than vero. Best of luck, though!
Leads is definitely easier. I tried the bridge of solder blobs method, but it was difficult and ugly. I’ve seen it done well, but I couldn’t get the hang of it.
Using the leads is the better option, unless you plan to replace components. Have a solder sucker pump and wick ready.
Additional and longer connections can be made using insulated wire.
What does this mean? “unless you plan to replace components”
Are solder bridges rough on components? Is it because of the prolonged heat while making the bridge or more like solder bridges make for a weaker connection which ruins components?
On regular PCBs you just cut the leads after soldering. In case you have to desolder a component that is way easier than on a
perfboard if you bent the remaining leads to make connections to other parts.
With a proper solder iron excessive heat on components isn't a problem.
