Woops is my middle name
I have seen many pedals using op-amp output buffers that include a resistor to ground after the output coupling cap, often 100k, and sometimes also with a small value resistor in the audio output path, like the 470 ohm below.
I'm trying to understand the purpose of these - I guess the 100k ohm would make a high-pass filter with the 1uf cap, and the 470 ohm does.... what? I get having the cap there to isolate the op-amp DC from the audio path, but not sure why you'd need a high pass filter, as opposed to just doing a 1uf cap without the resistor.
If anyone has any insight, that'd be great! This is from the Sea Horse, if that has anything to do with anything.
