guys have been trying to tame silicon fuzz faces into germanium for 50 years now and nobody's completely gotten there. we're not all suffering mass delusion and the market has borne that out over time.
If we are being honest with ourselves, a well tuned Si fuzz has every bit of the sound qualities we expect from a Ge unit.
But…With that said, I'm not sure the sonic differences are objectively differentiated if the circuits were tweaked to ape one another. For instance, if i had a primo example of a good Ge Fuzz Face, my opinion is that I could clone that device using Si transistors and circuit tweaks, frequency shaping caps, etc. and have a legitimate chance at fooling someone in a blind test.
I've never seen a circuit shootout with an Si device setup to mimic a Ge device exactly, i.e. I build a Ge device as a control then build a Si device to mimic that exactly, to the best of my abilities, and do a blind test.
With the Ge, it reminded me of a Ge fuzz face; kind of thick, and round…unless you playing into a hot amp, which adds the hair and grit. The Si version sounds like the later example, but into a clean amp.The Tonebender family, specifically the MK II, have shown time and time again, at least in my circuit building, breadboarding, etc. to really thrive with Si transistors.
For a while I used to offer a caveat to those I gave advice on the MK II/Supa about how i thought the Ge units gave the circuit a more tactile feel and that note bloom, feedback and sustain was better with Ge.
In the last few months I've been experimenting, here and there, with full Si MK II circuits. One of the things I always disliked about the schematics floating around was how they used much lower voltages on Q1 and Q3 when using Si transistors. Using the more generally accepted MK II voltages, playing with B-C bypass caps, and tweaking the frequency shaping caps has yielded MK II circuits with almost all of the tactile playing feel, note bloom, sustain and feedback of the Ge units but with an overall tighter feel to the lows and crunch.
I don’t remember off hand what the Ge ones were, they weren’t anything special, maybe 2n1303, HFE around 85/130.The Si ones are 2n3906.Did you use the OC transistors?
Good observation.Having played a number of what i would consider textbook examples, I think those OC-xx transistors, the 75 and 81x in particular, have a certain something in the treble frequencies that give that characteristic Tonebender "kerrang".
I think that's why Silicon transistors work so well in those circuits.
Ge FF is great for early Hendrix. That’s about it, in my experience. Si is way more versatile…Fuzz Faces are where things get more difficult.
I just meant it sparked discussion—not that people were upset. Although, those things listed above are the kind of things that make people get super bummed out about TGP and other hype ad copy.If anyone is really riled up we are doing something wrong...
Plus we need fodder for "It's All in Good Fun" now that everyone is removing their white washers and has thrown their cloth wire in the garbage.
Funny you should mention the Fuzz Factory. Been playing with my own build here. Started with a set of MP20a's and just the other day popped in some AC127's. Difference was amazing. Actually preferred the MP20a's. Now..that said, I'm super curious on what a set of silicon transistors will sound like by comparison.I think the best way to see the differences is to take things to an extreme ... for instance, zvex does a demo of the silicon fuzz factory where all the subtle differences between si and ge get very exaggerated and apparent. as far as some sort of challenge, guys have been trying to tame silicon fuzz faces into germanium for 50 years now and nobody's completely gotten there. we're not all suffering mass delusion and the market has borne that out over time.
Do you think the difference was in the part number or in the measurements?Funny you should mention the Fuzz Factory. Been playing with my own build here. Started with a set of MP20a's and just the other day popped in some AC127's. Difference was amazing. Actually preferred the MP20a's. Now..that said, I'm super curious on what a set of silicon transistors will sound like by comparison.
Might be the difference in the type of transistor. PNP vs NPN. Given that the Fuzz Factory isn't exactly a biased circuit per se, it would seem that a PNP might be a bit tamer than an NPN with similar hFE measurements. I put the same AC127's in a Fuzztone '69 circuit and they just sang. Bias on the circuit makes all the difference.Do you think the difference was in the part number or in the measurements?
