SOLVED Germanium fuzz not working
Johnnyorange500
Hi,
I’m having a bit of trouble with my Germanium fuzz face build. I seem to think I’ve soldered every wire correctly but I’m not getting any fuzz through the pedal. There’s just a dry guitar signal coming through the bypass and it also switches it off too. So I’m guessing the foot switch and input and output jacks are fine. I’ve just bought a new 9v battery too. All the capacitors and transistors are giving off an electric reading so they haven't burned out. I’m completely baffled as to why it’s not working. Would be very great full for some advice.
Johnny
Hi,
Johnny
What are your voltages? and post pictures of your board and bypass wiring, including the switch and jacks.
Managed it
Sorry guys I’m pretty new to using this so if you could point me in the right direction to what selection to use.
BTW, I'm looking at the pictures and it looks like you sent the red wire to the pot ? and black to the board. I would suspect that to be reverse polarity. You red should be the + and go to you board.. no ?
