What Bret & Chuck said.
Germanium diodes vary widely in leakage, even among the same batch of the same part number. Using them as feedback clippers isn't a good idea, but in a case like this, they MUST be selected for low leakage. That means picking ones with the highest reverse resistance. I've found some that are 6M or more on my Fluke 83V, which the company says tests at below .6V.
The closest through-hole Si alternative I've found for a low-leakage Ge diode is the Bat46. It tests out around 10M reverse resistance. I think it'd make a great alternative for the G2, especially for use in the first clipping stage if you can only scrape together 2 low-leakage Ge diodes for the second stage.
The Klon gets away with wide variances because the Ge diodes are hard clippers following a low-impedance output from an opamp.
Conan, what is the riddle of Germanium?
FV isn't strong, boy, leakage is stronger.
